SO i have a question I have a 2nd block im not using and ive completely tore it down
Will i be able to use Stock pistons with this setup. Does anyone see any flaws potential disasters or issues.
Turbo Kit:
Holset HX35 turbocharger
obx turbo manifold
Custom 2.5" aluminum charge pipes [hot and cold]
Stealthmode Oil line kit
Silicone couplers / T-bolt clamps
Precision 600hp FMIC 31.5x8x3.
hondata
GReddy Type RS blow off valve
Tial 44mm external wastegate
Engine
F22A6
Bisimoto CAM lvl 2
Bisimoto Retainers and springs
Bisimoto Valves
block guard
ARP Head studs
New OEM bearings/rings
OEM Honda headgasket
port matching
valve porting
block will be heat tanked,
Tranny
h22a 5spd transmission
Competition Clutch Stage 4 clutch kit
Competition Clutch 12lb Flywheel
interior
autometer oil pressure gauge
apexi turbo timer----
Roll cage
stock seat
G-Force 5pt SFI approved harness set
suspension
traction bar
dc sportfront strut
password jdm rear strut
hasportmotor mount
hasport axels------
tein Coilovers----
MSD 6Al ignition ---
NGK 8 series spark plugs .020 gap---
Air Induction/Fuel:
obx air intake-----
ITB-------
RC 750cc injectors
Walbro 255lph fuel pump
Spoolin' Performance oil catch tank
Golden Eagle vacuum manifold
Generic breather filter
COOLING:
Custom mounted Aluminum Half-Size Del Sol dual-core radiator--------$65
Fail Safe 180* thermostat
One 12" slim electric fan
Turbo Kit:
obx turbo manifold
hondata
Engine
F22A6
Bisimoto CAM lvl 2
Bisimoto Valves
block guard
ARP Head studs
port matching
valve porting
Tranny
interior
Roll cage
stock seat
suspension
traction bar
dc sportfront strut
hasportmotor mount
hasport axels------
tein Coilovers----
Air Induction/Fuel:
obx air intake-----
ITB-------
RC 750cc injectors
COOLING:
