I'm in the process of putting a turbo f2b set up together in my 98 civic coupe. Motor is a stock f22a1 with an oem rebuild and a6 intake manifold. I plan on running a obx ramhorn manifold with 3 in. downpipe and full 3 in. exhaust. I've been leaning toward a .60 intake/.63 exhaust turbo but I'm still unsure if the turbo will spool up fast enough before stock redline. I plan on running no more then 12 psi but f22a's are a dime a dozen and the boost might go up so I want a turbo that would still be able to spool fast enough but still be efficient. I'm hoping someone will chime in who has some experience with turbo f22a's.
The only other mods the motor might see is
-h22 plenum and throttle body on the f22a6 manifold
-bisi cam
What size turbo for stock f22 on 12psi?
Would a .48 exhaust be to small?
About what rpm would it hit full boost?
Thanks for any help in advance.
-bisi cam
