I am about to start my turbo set up, since the cam is almost done, but i was curious to know if i will need a new fuel pump (walbro 255) and fuel pressure regulator, or can i use the stock. My DSM buddy is telling me that if i don;t upgrade the pump i will run into TONS of problems. Oh yeah and i am doing the AFC hack, and i heard u can use the stock fuel pump, but just wanna make sure before i start doing this
Fuel Pump
your buddy is full of shit... you can run the stock fuel pump up to i believe 15-16psi... in my mind i would get a fuel pump after 12 psi tho. also the AFC hack advances timing like a bitch.. you'll have to run 3-4º retard if not more... or just get a MSD 6BTM. also you don't NEED an adjustable FPR.HAN - ZiviCase10287
Honda-tech - zivicase
HMT - draztik
d-series - draztik
Team Integra - RacinMasonC
get a walbro 190 or 255 lph fuel pump. or if u just feelin' lazy, get an inline pump. better than not having enuff fuel available.
are u running the 'hack' with stock injectors? if u are going with the 'hack' and some 450 cc DSM injectors, it would benefit u to upgrade the fuel delivery in some way --either an in-tank or in-line fuel pump.
if u haven't bought the 'hack' (AFC or VAFC) stuff yet, u may want to consider getting a P06 or P28 ECU and socket it or have it socketed. then get a chip burner. pick some sort of free ROM editor (i.e. Uberdata or Crome) and read up about it. make a basemap for yourself and burn a chip.
then u wont have to worry about 1.) insufficient fuel delivery... which could make your motor go 'Kaboom'
2.) timing advancing too much at the upper RPMs... which could make your motor go 'Kaboom'
back to the main topic. just upgrade it so that when the boostbug bites u, u can turn up the boost and not worry about not having enuff fuel delivered. ...every1 gets bit by the boostbug.
just my $0.02
i am not planning ro going over 8 to 9 lbs of boost. And i will be purchasing the vafc next week. yeah i have been looking into an msd ignition and everything. Thanks for the coments, i am hoping to get the cam install done by next week...just need to get a new alt belt without ac, balance shaft belt, and new rocker arm assmebly bolt....then i twill be just putting everything back...thanks again
