As some of you know I've built my block for boost using Aries Piston (bisimoto) 8.2:1 cr. I got the car built and tuned. I'm using a light flywheel weighing 8 lbs and I'm noticing that it will get stuck in the RPMs. When I mean stuck what happens is this: I drive through first gear to second, push in the clutch and the rpms drop from 4 thousand to 3 thousand but instead of going down to an idle it is just pegged at 3 thousand RPM for maybe 3 seconds. I've seen it stay at 3 thousand for as long as 14 seconds... which is really annoying!
When i got it tuned the tuner said that the car likes to be wound up, I wasn't quite sure what he meant by this until now but I was wondering if this was an issue with the tune, the low compression pistons (which all make 170 psi dead on, when using a compression tester), or possibly my light flywheel?
I'm not too worried over it since driving the car like this is way better than not driving at all, but it's just annoying.
