Can someone tell me what the commonly accepted max HP for a F22 block is assuming that the tune is good? I looked around and didn't find a whole lot. I was also wondering if H22 ARP headstuds will work since I couldn't find any listed for the F22 although my wholesalers website is weird like that at times.
Boost on Stock F22A6
around 230-250 is reliable on a stock block, more with a built block.
but again it all depends on your engines health.
a leakdown check would be the best thing before doing anything.
Are you planning on building,semi sounds like it since your asking for ARP head studs.
As far as this situation is concerned, go with H23 head studs, H22 will NOT work.
could be like straightedge and do 20psi but he only ran it on the track.~Nick~
Originally posted by drummersteve7 View PostAre you planning on building,semi sounds like it since your asking for ARP head studs.
From there I'll have to figure the rest of the build out. To start off I want it to be as much of a reliable budget build as I can achieve but would like to DD w/ 275 to 300 on stock internals so that might throw reliable out the window, unless I tune for 300 and then turn the boost back down to make about 250 w/ 300 being reserved for track/race days. Even if I do blow the engine that'd be OK though. The local pick and pull is loaded w/ F22's for dirt cheap so it wouldn't really break my heart to have to buy another short block not to mention it'd give me an excuse to build the bottom end once that happened.
irony in your sig. lol. NA is best but you're boosting
I'd say if you want reliability, boost at 7-10 psi. Your pistons are the weakest link and the ring lands will break off probably before you get issues with cylinder head torque issues.
With stock internals, your always running the risk of blowing up your engine, especially in the 250-300 hp range. I'd just boost it safely and get a lower 200-230 hp on stock internals, or build it up a little bit and reach your 250-300 goal.Been a long time. Still alive...
Plan on getting a cam from bisi for 300hp with that boost like me...I would run 8-10psi with the cam and make 250-300.... Then to rely on boost making the power...I talked to bisi and its a very good combo for a D.D,.....AND ITS QUICK...Think about it....Last edited by WhiteGhost; 06-01-2010, 03:07 AM.Only give advice when I know or have done it and it worked
Originally posted by 93blackcb7 View Postive heard you can mess alot of s**t up with a f22 boosted just go with a h22 it would be better plus na cars are betterLast edited by WhiteGhost; 06-01-2010, 03:23 AM.Only give advice when I know or have done it and it worked
