now that my car is tuned and running great (just took out a modded STi ) i wanted to get my launch control set up...is anyone using hondata and give me some pointers?
Launch control
If you took out an STi, I assume you're boosted, correct?
If so, I would DEFINITELY use a launch control that cuts spark, rather than fuel. As far as I know, most ECU-based launch control setups only cut fuel. If you do that, you'll be running lean as soon as the cut hits. That could result in severe detonation under boost. MSD makes good spark cut launch control modules. That's what I would look into.
For your Hondata it works by adding Heaps of fuel, and Seriously retarding the timing. For memory you can set it to do a fuel cut, OR fuel and ignition cut.
Eg - On mine I add 25% extra fuel, and retard the timing by 40 degrees.
You need to be careful doing it, because it creates very high EGT's and fairly fast.
Start off by adding extra fuel - then start retarding the timing in small amounts.
My 5.7 LS1 Holden Ute
Im using hondata s100 with the launch control set at 4,500 rpms. I think im gonna lower that number but idk im just playing around with it. Works good thoughALL PARTS MUST GO
http://www.cb7tuner.com/vbb/showthread.php?t=157038
Link to my turbobuild/members ride
http://www.cb7tuner.com/vbb/showthread.php?t=110483
Originally posted by rossisalvage View PostIm using hondata s100 with the launch control set at 4,500 rpms. I think im gonna lower that number but idk im just playing around with it. Works good though
really? mine's set @ 3500 (on eCtune) and i wanna raise mine.
mine USED to be variable, but the tuner switched it when i got dyno'd, so now when i'm @ the track attempting to do a burnout, since the track is so slick, 3500 isn't high enough so when i dump the clutch i just get CRAZYYYYYYY wheel hop instead of spinning the tires
i'm pretty sure there's 2 different ways to setup launch control on eCtune, and i prefer the first way i had it
Originally posted by twokexlv6coupe View Postreally? mine's set @ 3500 (on eCtune) and i wanna raise mine.
i'm pretty sure there's 2 different ways to setup launch control on eCtune, and i prefer the first way i had itALL PARTS MUST GO
Originally posted by bigpoppa694lyfe View Postcan i get more info on that msd unit?
i have my anti-lag set at 5200 rpm.
member ride thread
DIVULGE MOTORSPORTS
Originally posted by rossisalvage View Posthahaha niice. Idk I feel like 4,500 is too high for the streets I might drop it to 4,000. I have gotten a couple good launches at 4,500 when my tires are warm and its warm outside, but usually I just spin for days haha. Maybe I just need some good tires and 4,500 would be good
i guess we should switch setups considering our driving style haha. 3500 sounds absolutely perfect for on the street, and 4500 would be perfect for the strip.
oh yea, your only supposed to build 1-2psi with the launch control right? nothing more?Last edited by twokexlv6coupe; 04-26-2010, 09:59 AM.
Originally posted by twokexlv6coupe View Posti guess we should switch setups considering our driving style haha. 3500 sounds absolutely perfect for on the street, and 4500 would be perfect for the strip.
4500 on the strip will just make you bog, you would need to go much higher than that!
Originally posted by deevergote View Postwhy would you want launch control for the streets anyway? That's idiotic.
member ride thread
DIVULGE MOTORSPORTS
