2 Questions
    2 Questions
    Can we use a recirculating bov and use the stock eclipse gsx turbo mas sensor
    reason im asking is cus i want to put one of those intakes off ebay for the turbo ill be running and its the stock replacement intake for a eclipse turbo. i know where there is a stock dsm sitting at a junkyard i could snatch the mas sensor off it.
    miss my turbo cb7
    I think more information is needed. Which intake system are you looking at. The one for the DSM or the one for the CB7, or the generic ones for either cars, the manifold or the intercooler piping or both? I don't really know where to begin to give you a proper answer.
    Been a long time. Still alive...
      Its a direct replacement intake for a gsx eclipse, just its a aluminum pipe. U could go on ebaymotors and type in gsx intake and they will be right there. I'm at work on my phone so I can't post up the link
      miss my turbo cb7
        do you want to use it run the car in place of a map with or just to see the data?
        spin city
          no im going to delete the stock map location and rewire it to the gsx map sensor
          i want that intake in my accord using the gsx mas sensor
          miss my turbo cb7
            nvm found out forced performance makes a pipe without a bov return for 80 bucks. this made my headache less
            miss my turbo cb7
              what kind of engine management do you have? I don't understand why you would want to get a MAF in place of your MAP.
              spin city
                I was just going the same place in my mind - why are you trying to fit a MAF sensor and a recirculating bov?
                My baby laying down some power...
                http://www.youtube.com/watch?v=kd_Q8HSIyqA
                  i guess its hard for you guys to understand.
                  DSM's do not use MAP they use MAF. and i wanted the ebay gsx turbo intake for my dsm setup, but it requires to bolt up the maf sensor. thats why i wanted to see if i could rewire the map to the maf and give a reading to the ecu.
                  miss my turbo cb7
