dsm turbo setup,Manual Boost Controller needed?
    Planing to run a 14b turbo setup and just wondering if we need a Manual Boost Controller and if so how do u instal it.
    thx
    Henry
    Great achievements result from great effort
    only if you want to run higher or lower then 8 psi. I think that is what the 14b wastegate is set at.
    Shift_BOOST
    BOOM!
      you cant run lower. only higher. and it just Tees off your wastegate vaccume hose. easy as cake to install
        I thought there was a way to make it run lower... I don't want to run 8 psi daily.
        Shift_BOOST
        BOOM!
          not with a MBC...you can shorten the wastegate arm to lower the boost a little. but you kill spool time a lot.
          why dont you want to run 8psi? i do it everyday...50 miles a day. and i have 200,000 miles
            I know you can run boost with high compression, but I would rather run 6 psi daily on 9:1 compression. Then tun it to 8psi on the weekends. I would get kinda paranoid if I ran 8 psi daily on that compression.
            Shift_BOOST
            BOOM!
              9:1 compression is not high by any means...stock f22 is only like 8.8:1 or whatever. you will be more than fine with 8psi, and it will be much more reliable because the wastegate will be more stable
                How much do you think I could run before getting border line of bending a rod or something? I PM'd you too.
                Shift_BOOST
                BOOM!
                  probably like 13-14 before shit starts to break...thats the highest i would ever go. but 8-10 is pretty safe
                    hey Accord R33 are u selling any chiped ecu?
                    I need one
                      i can chip one...but no i dont have any laying around
                        You can, but it requires getting rid of the internal wastegate and installing an external one.
                          if i use a mbc will i be able to run 10 psi with the stock 14b wastegate? i know it normally cuts off at 8 psi. can it be taken higher without replacing spring?
                          I hate thieves!
                            yes. you can go higher, just not lower
                              excellent
                              I hate thieves!
