Turbo with A/C?
    Turbo with A/C?
    Is anybody running a turbo setup with A/C?
    Iv'e searched but havent found any setups like this..
    It's possible.
    Just take measurements and fab up a manifold that will clear a/c (and p/s if you still want it too).
      Midnightrayne, gdout90accord.
      My 5.7 LS1 Holden Ute
        It'll probably take a custom manifold, almost definitely require removing the front motor mount (or replacing it with the ESP mount), and you might not be able to run a very big intercooler, if you can even get a front mount one at all. (it'll be kinda hard to run the tubes to go around the A/C and to an intercooler. As you can see with those pictures, the turbo is practically in the center of the car, it'd take some weird pipes to get it to the front driver's side and run a big intercooler) This could be the kinda time where a custom hood would work nice though.
          The best way to clear for A/C would be buying a logstyle manifold. Revhard and Turbonetics manifolds for the F and H series work but you are "limited" to how much power you can make safely without boost spiking. If you are power hungry and expecting to make over 350+.... these manifolds are not the wise choice and it's better just to ditch the A/C.
          Boost spike does not feel good at all and will kill you motor in time....
          My friends greddy GSR didn't take a liking to it and he got rid of the car after it had problems when he maxed out the kits efficiency far beyond what it was supposed to do. Manifolds are important part of your kit and will partially set the limit on what ur motor will be capable of.
          I'm working on my H22a turbo project and I really want to keep A/C and I have a custom old style log manifold. The new design of the typical log manifolds can be bought on e-bay and have the wastegate in the center (like the logstyle above) This makes sure the runners are getting flow equally. The old revhard style has the wastegate portion above the 3rd and fourth runners which makes the 1st and 2nd runners further out of reach as far as flow. If you are boosting for the 300-350HP area as the revhard/turbonetic were designed then you will be just fine.
          I am the Yakuza CB7!
          JDM 96spec H22A 178HP 149TQ
          "The JDM Fleet"
          1993 Accord Sedan - 2.2 JDM H22a
          1994 Prelude V-Tec
          1999 CL 3.0
          2000 Prelude
          2010 Accord Crosstour - 3.5
          1993 Mirage S Sedan - 2.0 4G63 Project Evo 2.5
          1994 Mirage S Sedan - 1.5
          1991 Isuzu Impulse RS - 1.6 AWD Turbo
          1993 Asuna - 1.8 "CDM Impulse XS"
          1993 Sentra SE-R - 2.0 SR20de
          1995 200sx SE-R - 2.0 Sr20ve
            When you have built a turbo F22 you input might help.
            Your input in the above statement is full of lack of understanding.
              Look in the engine bay and see how much room there is to work with. If either of the above pictures were F22s you might see how those setups appear to go right through where the front engine mount would normally be.
              Some people find it best in situations with small amount of room to build upwards, in which case you could use a bulged hood and make ever so slightly more room (same way that Eclipses made room for their large cam gears)
              I was wrong about the intercooler, you can get the pipes to reach it even with the A/C, but it's not as easy
              Your best bet if you really wanna run your air conditioning is most likely to remove the power steering and relocate the A/C pump to the power steering pump bracket (may require some modification) and figure out how to either line it up with its original belt on the crank pulley or with the power steering belt on the crank pulley. If you line it up with the power steering belt you'll need a new pulley on your A/C pump though to make it have the same size ratio with the large half of the crank pulley as it had with the smaller part of the crank pulley.
                Both of those are F22's / H23's which are the same anyway
                Most CB turbo setups require a custom front engine mount reguardless of A/C - thats a know fact
                Ic pipes with A/C is different by about 1 inch
                  i've kept PS and AC without doing ANY modifications to either system, and only needed to notch the front mount about 1sq. inch. log manifold.
                  also running the piping was insanely easy and straight forward, only needed to ditch cruise control and washer fluid.
                  old H23;
                  new F22;
                  BB2F22-T3super60:250hp/275lb-ft @10psi
                    old H23;
                    new F22;
                    noooo not the washer fluid. you need that shit.....
                    ps i would suggest going costom made mani.
                      lmao
                      i've since FULLY deleted PS, and since i'm getting a DD pretty soon, then i'll delete the remaining AC, ABS, and fusebox, weld all extraneous holes shut, and MAYBE wire tuck. then i'll keep turning the boost up, she how much abuse she can handle (while building a motor on the side) and once the motor is out, get a paint job including the engine bay. mmmmmmmmmmmm
                        Are there any well known places that make good custom manifolds??
                          b18c8 bumpin this b
                            b18c8 bumpin this b
                            Why are you asking a question about manifolds, in an A/C thread?
                            Go see Bisimoto, he makes great manifolds.
                              old H23;
                              new F22;
                              I noticed you had the half radiator.....I thought A/C was not possible with those, that it only had enough oomph to cool down the engine. How does it work?
                              '94 JDM H22A: 178whp 146wtq
