retard timing?
    retard timing?
    do i need to retard my timing at all to run 8 psi boost? or is 16 degrees ok?
    TY
    More info on your setup would help answer your question. Backing up a bit of timing is nice to keep things conservative.
      you'll need a boost retard setup when you hit boost.
        93 honda del sol
        minime motor
        d16y8 head
        d15z1 block
        garret t3
        p07 ecu ( im really not sure if its tuned or not but most likely not)
        pretty stock other then the turbo
        seemd to run ok i dont get predetonation or anything like that, i think ill try like 14 degrees like nail said. next i have to figure out the tunning of teh ecu ...
        i just bought this ride and im fixin it up, previus owner didnt kno wtf he was doing.
        shame on me lol.>.< i hate civic forums thogh, this is best forum :P i used to have an accord
          What are you using to tune? With Crome, i'm able to use the degree per psi feature. I would go with probably at least 1* or 1.25* retard per psi of boost...but I don't know your injector size, CR (guessing above 9:1), etc
            To me that's way to much...1.25* x 8 = 10* he'd be pulling off a stock sohc rom..which probably has timing in the high to mid 20s....so say its at 28* at 5krpm..now he would be at 18* at 5k @ 8psi. = too much pulled imo..
            Without a wideband thou..I wouldn't touch shit anyway..
            Set your distributor timing to factory and use crome to alter it..not the other way around
            Praise The Lowered...
              The "I don't know if its tuned" ECU concerns me... that should be the most important thing! Get that thing tuned.
