Boosted f22B
    Boosted f22B
    I see all the dsm custom setups are done on the f22a motor, anyone do one on the f22B? I am planning on doing it and wondering if anyone had a basemap for it on uberdata.
    What do you guys think, 6-7psi on stock internals at about 9.3-9.5:1 compression? I think it would be fine, just want to see if anyone thinks otherwise. Eventually I would get low comp pistons so I can raise the boost, but for now I'm running stock.
    Shift_BOOST
    BOOM!
    we're not in the old days anymore so u really don't need to lower the compression...i'll actually be going higher myself in the long run. I can make u a basemap in uber just tell me all the details of your setup and if you have access to a dyno w/ wideband, or if you'll be buying a wideband yourself
      how do you not need to lower the compression? Maybe I'm low tech or something, but I thought forcing more air into a high compression combustion can result in premature detanation and possible the loss of the engine.
      I'll be getting a wideband o2, and I know theres threads on this in the uberdata forums, but I'm still learning so I was wondering if there was a premade basemap.
      BTW, I'm not planning on turboing till mid January, when I have my whole setup pieced together. I am going to the junkyards to get a p06 ecu next week, along with some 5th gen rims .
      Shift_BOOST
      BOOM!
        im doing boost. i dont have a f22b but i do have a h23 and i have the turbo manifold. u can use the h23 turbo kit for the f22b. no problem at all. im doing a full built motor and im doing 10:1 pistons high compression forged pistons means fast spool up time. low boost/ horse power
          as long as you aren't running too much timing and are under good a/f ratios then you won't detonate. Ppl run 11.0:1 comp ratios and make plenty of good non-detonating power its all in the tuning and how much u know about engines. With high comp u don't need to run as much boost like oneoffaccord said. But your engine will need to be more finely tuned
            I'm doing a dsm setup so I don't need an h23 turbo parts. I thought the f22ax exhaust manifold would fit, or is the h23 and f22ax the same manifold? Ehhh, I don't think I'm going to up compression, and I guess I won't lower it. I can't lose this engine because it's my daily driver and I need it. and of course the timing will be retarded slightly, since I will only run like 8 psi max, and the a/f will being running on the rich side till I have the time to tune it with the wb o2 and get the max power out of it.
            Shift_BOOST
            BOOM!
              you can you the h23 exhuast manifold they are the same for both h23 and f22a/b.
