compression ratios
    compression ratios
    i know this question has probally been asked soo many times but im not good with the search tool so here are my questions?
    usdm h22 compression ratio?
    jdm h22 compression ratio?
    has any1 turboed a jdm h22 with out lowering compression first?
    www.2camcrew.com
    go here , it's a sticky I wrote a little while ago on the accord engines. You'll find the specs there. And DON'T turbo an h22 without dropping the compression under 10.0:1., You'll probably blow your engine otherwise.
    Shift_BOOST
    BOOM!
      thanks helps a lot but i thougth usdm and jdm compression ratios were diffrent
      www.2camcrew.com
        Engine: H22A7
        Year: 97-01
        Trim: Accord TypeR
        Hp: 220
        Tq: 163
        Displacement: 2157cc
        Compression: 11.0:1
        Valvetrain: DOHC, VTEC
        The other might be 11.0:1 also, but I don't think it is.
        Shift_BOOST
        BOOM!
          thats not true just run low boost nomore than 7psi thats all and make sure its well tuned by hondata or aem ems no hack afc shit and youll be fine . Remember its not the engine that causes shit to break its tuner and driver.
            very well put. BTW, compression on stock USDM is 10.2:1 or 10.4. i know for sure JDM is 10.6:1. type-s and type-r are 11.0:1 anyway, stock bottom end, 5-8 pounds of boost, and good tuning= boosted h22!!!
            178 whp and 148 torque (mustang dyno)
            14.8 @ 93 in 1/4 mile-in Accord
            ??.? @ ?? in 1/4 mile-in Civic
