gdouts dyno sheet comparison
    Originally posted by rexload View Post
    over 40whp gain at same psi after head/IM work and meth - I must say that is pretty amazing . great numbers
    thanks bro, im excited for you also that thing will have the weeeeeeeEEEEEFFeeeeeelinngg
    hit me up on aim man.
      rep that TX boost
      now we should run, i wanna see how bad u pull me
      Formerly 91AccordExR33
      11.68 @ 127mph
      417whp/375wtq
      Sold: 8/2016
        what duty cycle were the injectors at?
        spin city
          Im wondering is your motor built? or non built?
            Stock block sparky...
            And dbsharp.. at 11psi/6krpm = 101% D.C
            I sent him some 780cc precisions already..he just has to get them cleaned and flowmatched..
            Praise The Lowered...
              not bad man definitely take care of it and stay on top of the maintenance. Boost gotta love it. Nice number bro
                So he's still rocking the 450's? And I don't like going off the DC on Crome. I look at the injector duration portion of the graphs. Much more accurate.
                  ive been on 560s for a while, like carlos said i need to get the 780s cleaned and flow matched. i need to look for a good shop to do it, you know any?
                    injector rehab
                      You should be good to about 340whp or so on those, especiall with such a low redline. I've taken 450's to 300whp.
                        I like having the extra room..so some clean/flowmatched 780s is the answer..
                          what he said
                          d11crzy thanks for the injector rehab, i emailed them and had a quick response so
                            Originally posted by gdout90accord View Post
                            the clutch was from lsd motorsports and it was the lsd racer clutch 6puck sprung disk. when i bought it 6months ago it was rated at 3xxft/lb (suppose to be) and now it says its 264ft/lb so .
                            Ah. I had a stage 1 from LSD Motorsports for my red project because a friend referenced me saying I could save money. It was a "clutch specialties" brand. Unfortunately, it lasted me only 40-45K miles before it started slipping on me as well. Last time I'll buy from them, I should have stuck with my gut and gone with stage 2 Spec. I believe in going one step above what you need and stick with reputable clutch companies as it is critical to putting torque to the ground!
                            Honestly, a 6 puck should be capable of more, especially being considered "racer". They must use cheap pressure plates.
                            Stick with Competition Clutch, Action, ACT or Spec brands.
                              www.cruzinperformance.com does injector cleaning and flow testing. Great prices and turn-around time.
                                didnt you use injector rehab also?
