So, I've been toying with the idea of a supercharger for some time.
I do not want a turbo because it isn't a bolt-on in my opinion, so please don't someone post "get a turbo, its cheaper". Well, no, to me it isn't, it is also more complicated, less reliable and frankly, I don't like the idea of adding something that I cannot unbolt later leaving a path of destruction and damage behind - the choice of direction is made....
ANYWAY
This is more of a question of weather what I have thought up makes any sense, and what I might have forgotten.
In principle I'm thinking of using a small centrifugal supercharger (looks like a turbine) mounted before the throttle body to a modified SRI. The power would come from the belts of course, and there'd be a BOV in the SRI... The way I see it is that due to the lack of kits to F22's, this would be turbo-like in set up not requiring modifications to the IM. The original IM would be retained. This way, I would to some extent (I hope) allow the part-closed throttle to slow down the air at idle and avoid surging rpm, only to allow more power when the throttle is open wider for regular to sportier driving.
Other factors to consider:
- all extra equipment bracket mounted to EXISTING holes and openings
- pressure no more than 0.5 bar... maybe 0.3?
- larger injectors? would I need them? I don't want to make too much power... just enough to give modern cars a run for the money
- ECU tuning... I'd really like to avoid that if at all possible. Can I... please?
I have a pt3 and nothing else (even p12) works with my Japanese built CB7 because of a thingy in place of the O2 (IMA: Intake Mixture Adjuster, one of my posts explains all)... unless I don't know something...
Please, let's be constructive even though this may not work at all!
ANYWAY
