Ok so the other night i stopped at a gas station turned car of as normal then. When i went to start it back up it sounded like a boxer motor. So from past events i assumed an o-ring was blown. So i proceeded to do a compression test and it read like this 195,195,190,and 187. So i know the seals are still good. So i look at the spark plugs and saw this.
The one on the left is from cylinder 4 which i assume is firing and the one on the right is from cylinder 3 which i assume is not firing. So i have no clue why 3 is not firing but the rest are.
I just replaced the wires and spark plugs. Could it be the tube seals have blown and is just coating 3 with oil?
