Intercooler Dimensions
    What are some common dimensions run without cutting the front bumper. I want it to fit behind the plastic and literally want everything to look stock from the outside with a little IC peeking through if you know what to look for.
    whats good man, it all depends on your bumper. i cut mine but it stll look like it did before. are you talking something kindlike this
    before intercooler
    after intercooler
    length 28" height 7" and thickness 3"
      Somewhat. I dont want to have to cut anything. I want it to fit in behind everything. Im debating using my supra SMIC as a makeshift FMIC off to the side, or buy a new one.
        i highly doubt your going to fit ANY intercooler in your bumper without cutting.
        look at chessboxers setup. he hacked his bumper but you can barley tell.
        then just paint it black.
          here is the best example i can give u..
          stock srt4 fmic rotated..
          this setup works only if u dont have a/c as the intercooler outlets are backdoor(go into the engine bay) vs out the sides of the I/C
          the bumper was hacked.. but that was because it was a 91 bumper.. then the bumper was switched to a 93.. and the cross beams of the bumper were left intact.. no "hacking"
          here is the same car.. with a BIG srt4 fmic.. with the 93 bumper unmolested
          it was trimmed.. to clear.. but as you can see the bumper looks stock
          Praise The Lowered...
            neglect the fact that were working on it.. lol..
            another view
              mmm doughnuts
              wat?
                Cool, well thanks for the insight. IG ill have to start looking into a size that will require minimum cutting.
                  I told you an srt4 intercooler is best. Well the stock fittiment if you dont want to cut little bit of th bumper and have it lookin stock.
                    So there's more space behind a 9293 than there is behind a 9091?
                    Underground.Society
                    Originally posted by Deevergote
                    If it doesn't really matter... shut the fuck up and let it be.
                      did some measuring...cutting the bumper later....
                      24.5" x 11.75" x 3"
                      have to cut to be effective, good luck!
                      MadLab Racing
                      Southern Maryland
                        Thanks. I am going to have to cut, and bought a fmic lol.
                        Will be test fitting and installing a lot this weekend. Almost ready for booooost
                          http://precisionturbo.net/Wc21126d5f695d.htm
                          600HP" 1990 ACCORD LX COUPE COMING SOON
                          CLICK HERE TO VIEW MY 1990 CB7
                            When you put the IC in, what did you do with the PS cooler?
                              lose it. P/S is for nancies!
                              MadLab Racing
                              Southern Maryland
