wuz up you guys i just have a few questions. i have a fully build bottom end H23 with forged rods and piston heads and sleeves. well ofcourse i boosting it so i wanted kno how much psi i could run safely. i mainly worried about the valves how much can they take
Boosted fully build h23 block
500 is pretty easy. if you have a built block i highly suggest at a minimum springs and retainers. and a good turbo choice.
member ride thread
DIVULGE MOTORSPORTS
Originally posted by lildeez07 View Postim lookin for around 400hp to the wheels. my boy hit close to 300hp on his stock F22a1 at 16psi. so im pretty sure i can hit 400hp on a forged h23
My honda sitting on some Honda Accord Euro R Rims
My Parts for Sale HIT ME UP IF YOUR INTERESTED!!
http://s51.photobucket.com/albums/f356/fred1618/
Originally posted by 93sleeper View PostI think the save way to run the H23 is about 16 psi as well...No more than 18 psi. Depending on the parts and your turbo you should get about very good results but the H23 is more torque then horsepower. So if you should get around the same about of power as the F22a1 but your torque number will be higher. For example when I dynoed mine, I had like 296 hp but like 270 torque. You will see....you will love it!! Might want to look in changing the Intake Manifold....I ran with a golden Eagle....Top end is very nice with this upgrade...Later
if he is built with sleeves rods and pistons his bottom end is good for 30+psi
member ride thread
DIVULGE MOTORSPORTS
Originally posted by turbo90accord View Postif he is built with sleeves rods and pistons his bottom end is good for 30+psiOriginally posted by jm991700 View PostIts more so about how much power vs boost. b/c u can run 20 psi on one turbo and be fine. But 20 psi on a bigger one, my mess something up, b/c of the more power u making. If u stay below 400 ft lb of torque, u should be find.Torque is what breaks stuff.
Originally posted by lildeez07 View Postok well i have brian crower rods and piston heads. king main and rod bearings, and darton sleeves the crank has been rebalanced and micopolished there is no head work as of now but im saving up to get some new valve springs and retainers. and some brian crower cams.
I mean just saying you have pistons is like saying I have a car.
its not enough info.
but ohhh well, it doesn't sound like you want help at all.
I mean do you have high/low compression pistons?(numbers are good)
piston heads, (oxymoron) which stlye, dished?
so moving on to bigger and better things!
good luck!
BOOOM!
Im not offended, just wanna know exactly what your talking about.
You seem to have potential for a great 1st build.
Just wanna make sure all your questions are answered correctly.
and without all information your answers will not be perfect.
so despite anyone giving you shit, its a learning process.
Not just for you but everyone collectively.
lemme know if you need any help.
