We all know we need an oil restrictor for the DSM turbos. My question is this, stealthmode makes one, but as you can tell from fitting sizes (1/8 NPT) it goes into there block adapter or a sandwhich plate. does it matter where the restrictor is at in the line. I have heard both, "put the restrictor in turbo inlet" and "put restrictor at block adapter (oil psi unit) or sandwhich plate". does it really matter? i mean either way its going to reduce pressure.
if its at turbo i need to find an 12x1.25 fitting with 1/8' then 1/8 to whatever my line is, right now i assume its 3 or 4AN and have to still find out.
