IM change affects boost?
    Can a change in your intake manifold result in an increase decrease in available boost?
    Say from being limited to 8 psi...changing IM and now having 12psi?
    Ray
    1992 EX Sedan, Manual
    CB7Tuner Illuminati Member #: 18362
    JGY Honda
    sure your old one wasnt crack/leaking/bad gasket? 4psi is a huge increase though
    94 GSR | 93 GSR
      It increases your volumetric efficiency(if going with a better one), which will cause your turbo to spool up sooner and have the ability to produce more boost.
      Unless you do not have a wastegate and your motor ran COMPLETELY like shit, the chances a manifold change caused your boost to raise 4psi is unlikely.
      Sounds like what you did was change your vacuum source to your wastegate and or your boost gauge. That does make a huge difference.
        A buddy of mine has a car that was not getting any more than 20 psi. He installed a 120 wet shot kit, and a new aftermarket IM ... during his initial dyno pull with the new setup, he shows 27 psi W/OUT even using the NOS...
        I'm not too familiar with forced induction yet, so I'm curious to know how that could happen.
        Ray
        JGY Honda
          he could have altered the boost controller.
            his boost guage could be off...
            boost in a honda vs boost in a dsm, has showed me in a honda 4psi is alot, in a dsm, 4 psi, is barely noticable.
            "Self Renewed"
              Okay...so there are a few factors that could be involved, I guess.
              I had no idea that it would make a difference, but we're talking about a Nissan SR20DET with much work done to it...
              Ray
              JGY Honda
                Very significant detail being a completely different engine. What IM have you changed it to?
                My 5.7 LS1 Holden Ute
