Turbo high mileage motor...?
    I was wondering whats your guys opinions on turbocharging a F22a1 motor with well over 100,000 miles, I know its a stupid question but I want to know if its worth the trouble or if it is possible to keep the engine going longer with it well maintained??? Help CB7tuners.
    Glenn
    Red Devil Crew - Member 7
    FSAE (F Series Accord Enthusiasts) 5spd swap...100% done. Will post pics soon.
    F22a1-Turbo still debating...?
    I wanna turbo mine i have 277 babyy and its still going
      im turbo'ing mine, 174,XXX ...but im doing a rebuild before the kit goes on, so yeah...muwahahah...
      ^sold
        seee i only have 120k and i did mine, eric has 180,XXX....
        Turbo CB7 is Gone ...But I Still Come Around
        AWD TURBO IS THE ONLY WAY TO GO!!
          Mileage doesn't mean squat....compression tests is where its at .
          I have 185K on mine and I have no trouble throwing on a turbo on her...compression was all good
          No more cb7, 7 years of ownership and 196K on the ticker before she was sold
          Current beast: 98 ej8 on 7psi with a 15g turbo and other goodies!
          NREMT-B | 300D and some glass
            i have 190,+++ on mines...
            just got off of nitrous also.......car still running strong
            so i say it doesnt matter long as the car was well maintenanced and the compression checks out good.
            ofcourse its always good to replace little stuff that might help....gaskets, flush the motor and stuff.
            NEED RAP BEATS.....
            www.soundclick.com/akcidentaltrakz
              yes compression tests are the TRUE TEST!!
                OK, when you do a compression test across all 4 cylinders whats a good rating, or what should it be at??? I wanna turbo my car but I'm only going to be running maybe a T25, T28, or a T3 Turbine set-up I'm only going to be running on 5-7psi since the internals are stock.
                Glenn
                  well for one, they should all be around the same #, i dont remember the #.....but our stock internals can handle like 8-10psi bro
                    Wow 8-10psi thats sounds like alot, wouldn't it blow if you floor your cb7 alot though? Also what type of turbine can I run since i'm just shooting around 5-8psi??? Oh yeah I'm converting my car to stick shift first though heh this weekend hopefully if everything goes according to plan I'll post pics of it up ASAP when its done, who makes good Turbo manifolds, oh yeah I wanna keep my A/C, man its so humid and hot here in Hawaii, it either rains or shines thats about it.
                    Glenn
                      i still have my a/c after the dsm turbo mani...just gotta bend them....anyways...we have cast iron sleeves, our engines are one of the best honda ever made....take advantage of this!!
                        That's really not a good thing to tell somebody who obviously doesn't know much about turboing the cb7. The engine can handle that, but for how long is another story. I gaurantee it won't handle it for long at all without proper engine management and tuning.
                          again it depends on compression.....erics car has been turbo'd since july, my car is still running after a month LOL, i couldnt tell you more, but eric's has lasted a while, we both have the same setup....we just dont beat on our cars thats all....
                            Why turbo it if you're not going to give 'er????
                            Almost like training for a big sporting event and then not showing up...
                              not really....not all of us need to show it off all the time because we are insecure in other areas
                              you just know its there
