Fixed the oil pan and now to the next issue... help!
    Another update...I fixed the oil pan leak...it was a bad weld on the bung. o well...now my new set of problems...it is shooting oil out of the compressor side...badly. its all over that side of the engine bay. I'm guessing either needs a rebuild or theres a backup of oil in the turbo and its blowing past the seals. but I have a ss -10an return and a -3an feed. I believe its more than efficient. should I get a restrictor or not???
    also...I talked to a guy at a turbo rebuild shop and he said it doesnt sound like its the turbo b/c i already replaced the rings last yr. he said it could be a crankcase pressure issue.
    1993 Honda Prelude H23t -big 16g turbo, uberdata, and a kick ass body and paint to go with it!
    Id try a restrictor, as it could be blow by.
    Also, what brand is your big 16g? How many miles on the rebuild last year?
      Are you running a catch can? How is your PCV system set up?
        My friend had the turbo lying at his house...he got it in a package deal with a greddy fmic for his eclipse so he sold me the turbo. It seemed in good shape. and I only replaced the rings inside. the guy at gpopshop.com said that that could be a likely cause so I took the cheap way out...
        As for the catch can I removed it bc it imploded on me...i made one out of pvc and i guess it got too hot one day. I actually dont have any pvc running right now...I dont have a filter on my turbo so I dont kno how to run 1.
          Good to hear you got your leak fixed
          Your catch can imploded? or exploded lol?
          When you say it's shooting the oil out - Do you mean you can literally see it flowing out?
          Take the turbo to a shop and have it professinally rebuilt and balanced.
          The -3 lines should be enough of a restriction - I run -4 feed into my 16G and have had no problems with oil leaking past the seals.
          My 5.7 LS1 Holden Ute
            My plan is to get a cheap 14b that works just for an experiment...Ill put it on just like my 16g and if the 14b works fine ill sell it again and rebuild the 16g...i just want to rule that out for money's sake...a rebuild for it is like 350 :-/
              Changing to a 14B, means new tune also. Imo stay with the 16G, for economy around town, and better performance overall.
              Mmmm its a hard one - to do that just to rule out the turbo - $ wise that is.
                A rebuild kit yourself should only be around 100 bucks or so, I just bought one for my brother's 14b from forced performance, was about 112 shipped. If you send it off for rebuild, then yes, it will be about 350-450 which is rather expensive, as I just bought an MHI evo 3 ported big 16g for just over 500.
                If you don't know the turbo brand, it could be one of the ebay turbos, which could explain it going bad after just a year.
                Do you have any pics of the oil and the turbo?
                  Im not going to change to the 14b....im going to install it to see if it shoots oil out like my 16g is...if it does than its another issue u kno..
                  and also it is a Mutsubishi Turbo..its not an ebay one. I kno the rebuild kitsare cheap but ive had so many odd problems that im not ruling out anything yet.
                    Good deal man, just checking to be sure. Your car looks awesome btw.
                      hey chessboxer...the rebuild is doable tho right...I tore most of the turbo apart to replace the rings and it didnt seem bad...how'd ur bor's come out?? and thanks btw...i just want to get this car running. i miss it. i havent driven her in like 2 years
                        Has the turbo been sitting for 2 years? The internals could be bad from sitting for so long. And yes, the rebuild is doable, and I believe there is a diy on here from someone that did it.
                        My brother's rebuild kit is on its way at the moment, but when it comes in, I am sure he will be putting it in asap. Ill let you know if he has any pointers or anything when doing his.
                        I think I would go crazy if I couldnt drive my cb7 for 2 years.
                          noo I took the car off the road in nov. of 2006 and i started the project then. since then the turbo has been sitting...but i think im just going to bite the bullet and rebuild it...it will be worth it in the long run anyways...its only 120 from gpopshop.com and it will be an experience lol. what are u running on ur setup for management??
                            Chipped p06 running crome gold, although since I have been working at Haltech, I have been heavily contemplating running a haltech e6x or a haltech e8 as a full stand alone.
                              Who chipped your ECU Mike?
                              Confucius say...when god gives you gators...make Gatorade
