Ok when i install my wideband, should i also make a hole in the downpipe and weld a vibrant o2 plug and put my sensor in so that my car doesnt act up without a o2? or when tuning comes into play it will fix that problem?
Question on widebands
Originally posted by twokexlv6coupeif you have a chipped ECU (or anything better like an s300 or something), there's usually an option in teh software to turn the o2 sensor CEL off, so you only need one bung for the wideband in your downpipe.
You can set it up so it reads wideband and it has a narrowband output as well whis can be used at the same time - basically 2 sensors in one
My 5.7 LS1 Holden Ute
tune with both if you can. That way you can tune closed loop with the influence of the 02 sensor so you can judge how much swing the a/f has. I'd tune closed loop with it off first to get it close to 14.7 then add in the 02 and make sure it keeps it within a reasonable rangeKnowledge is power...in EVERY sense of the word
