obd1 realtime engine stat F&F- like software? lol
    ok i was thinking i could like hook up my laptop to the datalogger and maybe find some of that softwre they used in the fast and the furious
    so like right after a 150 shot of NOS it starts flashing 'Danger to Manifold' and I'm like 'Shut-up!'
    anybody know if this exists?
    lol, then slam the laptop closed and hit your "other" botle with a 250 shot.
      try at the myspace import auto forum. an answer may lay there
        hey guys im serio9us
        i know they hve realtime datalogging software where u can change things on the go, but i want some of that pimp shit.
          ....pointless and a waste of time when a gauge works just as well. How I see it you would have to wire some sort of sensor into the tank such as the run flat systems inside the newer car tires/or some sort of pressure switch for bottle pressure/capacity and crap. Pointless unless you feel like doing thw work. Just dl some fake software off the internet.
            lol im not just talkin about nos
            my VAFC died, and they are 350, im getting a chipped p28 and i ahve a laptop and an indash lcd not doin anything.
            basically i just want it to perform the duites of (as far as monitoring) as the VAFC
            pressure, RPM's, Throttle, oil pressure stuff liek that, maybe a warning if levels drop below what they should like oil pressure or fuel pressure.... nothing is impossible so ideas guys!
              learn to program yourself? lol. I posted something like this kinda not really in a ECU post. Basically making a 2 chip config ecu with burner it alternates between chips (one in use) while you program the other. Parts for the chips and to make the burner would be cheap, just gotta know something about circuit boards and programming. I dont believe it would be that hard to make a HUD, programming the voltage inputs for your regular gauges and wideband o2 to read as a analog output like RPM's and A/f ratio. Again you would need to know how to programming and something about microprocessors/controllers.
              Discussed the dual chip built in ECU burner for real time(or at least without removing any chips) burning with a electrical engineer said it be relatively straight forward just make sure you have a spare ecu in case
              ..It's not cheap to build a fast CB7, especially NA. However, if you're willing to put the money into the car, it's well worth it in the end. There ARE faster cars out there, but some people, like me, want THIS particular car to be fast!...
              Sold to:tanNn2koo,9tAkord,ThrakBarts,nahmo,andrizzle,or anger
              1993 H22A cb7 <3 miss you
              04 WRX stg 2 sedan
              Current - 02 WRX stg 2 wagon
                look into ecu control, freelog, and crome pro(you have to pay for this one)
                check out pgmfi.org
                  lol, you dont need to know anything about that, except maybe programing.
                  its simple.
                  you have a chipped ecu, a rom editing software that has data log capabilities, or a data logging program, laptop and a wide band, at minimum.
                  connect the laptop to the ecu. your ecu is already connected to everything else. you just log the info with your data logging program.
                  the trick is, you gota know what the information is and how to read it, then how to make any use of it.
                    ha ya right.. i feel like a genious in the myspace forums lol
                    My s13 Ride Thread>>><<<My Rx7 Ride Thread "What is power without control?"
                    New people click here
                      its simple.
                      right so like i would need some software thats realtime datalogging and shows graphs and shit anybody know of this? come on they had it in the movie lol!
                        and that customer at the shop ordered 3 sr-20 for his Civics !
                        1991 Sedan
                        click image for MRT
                        -Nava
                          THEYVE GOT SPOON ENGINES MAN! SPOOON!!!
                            yea, its called research.
                              Take a look at HonData
