Ok, here's an idea I came up with...
Back in the day, Cadillac had a V8 that simply stopped fuel and spark to 4 cylinders at cruising speed. Basically, when you didn't need the V8 power, you were getting 4 cylinder fuel economy.
I don't know how well that concept would translate to a 4 cylinder, but I figure it's worth a try!
Would it be possible to cut fuel and spark to 2 cylinders at a certain speed and throttle position? I would think alternating the cylinders doing the work would be a way to ensure even wear.
If it's doable with the software we have availible, the only concern I would have would be balancing issues. A V8 running on half the cylinders would be a bit more balanced than a 4 doing the same, I would think...
Regardless, would it work? Could it be done? Using throttle position and vehicle speed, would it be doable (and safe?) to run only 2 cylinders at a time?
