Does any one know what the factory total timing is on stock ecu for f22 and h22 if anuone knows.
f22 factory total timing
The distributor itself is stock set to 15 degrees advance, but because it is an electronic distributor the ECU will advance or retard timing based on engine speed, load, and other sensors such as knock(H22, H23, F23 only afaik) and O2. It's not static, but iirc from other tuning threads stock is something like 20-25 degrees advance, increasing as the rpm increases. I believe there was power increase up to 28-30 degrees advance near redline, but I can't find said threads to back this up.
Yep I new 15 was idle wasn't postive on total I know b16 is 28 but I didn't think the f22 would be the same. I'm going to be a idiot and build a old school msd btm fmu with 450 injectors on my rail buggy and see if I can tune it as much as could be with fmu. Would like to make 350 whp if possable. I know its not the best thing to do but somthing I allways wanted to try. If and when I blow it up I'm building a forged 2.3 and tuning prob with s300
use a rising rate fuel pressure regulator and a 10:1 fmu, paired with a walbro 255 pump and you should be good to run minimal boost.
i dont know about no 300 ponies with no real tune, but you could certainly and safely squeeze out a couple hundo and get away with your ghetto ass fuel management approachOriginally posted by wed3kim a douchebag to people and i don't even own a lambo. whats your point? we, douchbags, come in all sorts of shapes and colours.
I will most likely use the begi fmu so I can adjust a lot more coming in to boost. But I built a ls integra in 01 with a junk vortec fmu on 360cc injectors lowering fuel to 26 psi to scale back injectors and a 8 to1 fmu and msd btm it made 230 whp on 13lb. It ran for almost a year. At the time I didn't know the value's for the msd were wrong when I thought it was taking 1 deg. Per pound out it was only taking .5. So I want to mess around and see how much I can make
