EGT sensor placement ?
    I'm trying to find what is considered the best placement for a egt sensor on a h22 with a 4-2-1 header. It says too place it as close too the cylinder head as possible, but if your only using one sensor do you want too wait until all for cylinders are feeding into the exhaust or do I put it closer too the head and just read 1 cylinders temp ?
    CB7TUNER.com
    Educating each other one car at a time.
    Average temp downstream will be less useful than a single temp upstream. If you're using it for tuning just put a fitting on each runner and check them individually.
    '93 H22A 5SPD SE - MRT - DIY-Turbo Sizing
      That sir sounds like the absolute best way too do it.
      After tuning would down stream be useful for monitoring your motor ?
      CB7TUNER.com
        http://www.sdsefi.com/techegt.htm
          Originally posted by illinois_erik View Post
          great read, read it already or one like it. thanks
          CB7TUNER.com
