hondata map sensor
    hondata map sensor
    hi guys im trying to wire a hondata map sensor but not been lucky can someone help me out with this?
    **im using the stock map pigtail
    Should be:
    GRN/WHT wire = 5v Positive (+)
    RED/BLU wire = Sensor Ground (-)
    YEL/WHT wire = Sensor signal (+)
    The rest of the info you need is here - http://www.hondata.com/tech3barmap.html
    My 5.7 LS1 Holden Ute
      evil_demon thanks for replying to my question!!
      Im still unable to rewire the map sensor due to different wire colors from the accord harness plus i been looking on the net for a pinout for the hondata sensor since it never came with a pigtail , on the accord harness it has different color than the sensor harness(OEM sensor) the hondata is 4bar don't know if there is any difference from the 3, 2.5 other sensors. for now my car starts on stock sensor and only idles no boost and i m not trying to go crazy so hope to find some good help and figure this out before moving forward... thanks again !
        4 bar sensor uses the same sensor as an H22 throttle body mounted swap . . . http://www.hondata.com/4barmap.html
        Your lack of info makes things complicated.
        Stating it was a 4bar Sensor should have been the first thing you said.
        Now:
        What engine do you have?
        Where is your current Map sensor located (Throttle body, Firewall, or Vacuum box)
        What color's are on your pigtail?
          You right evil_demon i meant to put the sensor type my apology
          well i have a f22a and the map sensor is relocated under the glove box inside the car. since the accord didn't have the same pigtail i have to use the TPS from an extra f22 harness.
          from the accord harness (not the map sensor) i have :
          white / blue stripe
          red / white stripe
          blue / white stripe
          *if there is anything else you need please ask i do my best to help you help me with this
          i would need where exactly the wires go to
            why is your map sensor so far away from your intake manifold, this will result in delayed response time as well as variations in vacuum readings which can cause a shit tune.
            member ride thread
            DIVULGE MOTORSPORTS
              turbo90accord i'm not leaving the map sensor where is at now, that's why i need to figure out the connection so i can make a harness to extend and bring out to at least behind the plenum, for now i have the stock one so at least i cant turn on the car and that's all i need in order to get it tune
