37820-p13-a10 ???
    37820-p13-a10 ???
    Hi, I'm wanting to know if someone can identify this ECU?
    I know it's for a USDM H22 vtec but wanted to know if its a 50 or 49 state also if its for auto or manual trans. My car that it would be going into is a manual trans if that matters. Thanks
    1993 Accord LX Coupe 5spd
    These specs were taken from Hondatech after a quick google search
    P13-L10 is CA for 93-95 and replaced by L12.
    P13-A10 is other 49 states for 93-95 and replaced by A11.
    P13-N00 is JDM.
    also see..http://www.cb7tuner.com/vbb/showthread.php?t=140325
    Its for a manual trans..I'm not sure if there was a USDM p13 auto. The 97-01 Preludes didn't have p13s.
    edit: How to identify your Honda ecu http://www.rywire.com/catalog/identi...r-ecu-a-6.html
      Thanks, I've seen that other thread you posted the link of but was unsure about the P13-A10 because the thread identifies the P13-A11...are these two ECU's the same that you know of? Are both 49 state USDM?
        They are both USDM 49state manual ecus. The A11 instead of A10 is just a revision.
          Thanks 5SP5DRCB
