Need a base map for an f22a6 using a delta 272 grind cam. Any help is appreciated
Base map needed, Chrome or Neptune
I am aware a tune is best but I don't plan to have it tuned until the rest of the project is completed. unfortunately I have to install this cylinder head now due to fault with the current stock one so need a basemap for usage until then. my ecu is Shue tuned for my old 400hp sohc setup so that will not work. I am using chrome currently so that is ideal but will be moving to Neptune later so if that has to be done now that Is fine. if I can't find a basemap so be it, but why shouldn't I try?wat
Someone else's basemap is not going to work on your motor, they are motor specific. Just a thought...1993 SE Coupe MRT - 1992 LX Sedan MRT
93 Accord SE Bose Stereo MYTHS & FACTS - F22A* Power Plant Removal(UNDER CONSTRUCTION)
