P12 ECU Power ROM
    P12 ECU Power ROM
    Anybody modify a P12 with this chip?
    http://qcwo.com/otherdeal/Racing-Chi...P12-ecm-HP12C7
    91 Accord LX 5-speed
    93 Accord LX 5-speed
    Boom.
      Boom.
      "My FOR SALE thread - Click here"
      MEMBERS RIDE
      99 SILVERADO
      WHEEL FLIP
        Boom.
        Originally posted by drew12000 View Post
        You will be surprised and satisfied with the results obtained as soon as you install this chip!!! It's time to unleash the power that is hidden under the hood of your vehicle!!!
        Revlimit (Red line) was raised up to 8000 RPMs
        BOOM!!!!! looks like junk to me
          I've never used such a chip, and I've never stuck my dick in a blender. Neither is something I would ever do, and I'm quite certain I know the outcome of either scenario.
          No chip should ever be installed in your car unless it is custom tuned for YOUR engine.
            I take that as a NO. Nobody here has installed one of these Power Chips. I do not get the Dick analogy? It guess depends on how long your Dick is!
              Give it a try man. And let us know how it turns out. Who knows, it may actually be worth it.
              MEMBERS RIDE
              99 SILVERADO
              WHEEL FLIP
                He sells two different chips the A12C7 and The A12A9 the C7 is for the A01 or L01 ECU and the A9 is for the A00 or L01 ECU. The A00 ECU is more like the JDM Version of the ECU according to the code and the A01 is U.S. Spec. That is what the seller told me. Now the chip can be bought for $40.00 with a Coupon on the website. Humm? I do have an extry P12 that I can play with.
                  You might want to ask if anyone has a spare F22A while you're at it. That chip could potentially blow the motor up.
                  Plus, the P12 is tuned pretty well from the factory. There's not much more power to get out of a stock F22A1, and any mods will most certainly render whatever tune is on the aftermarket chip invalid. Unless the ECU is specifically programmed for the setup it's meant to run, it's not going to be worth a damn, and could do damage.
                  And yeah, I suppose the dick in the blender analogy was a bad one... I could stick my dick in a running blender and be totally safe!
                    Yes I agree, there is not any Info to support the claims, plus is it a drag tune, road racing tune, what parameters were changed? now if I had received some positive feedback, dyno plots or any other evidence then maybe it would have been something to try. I am happy with my current MPG to power ratio (30MPG AVG).
                      I also don't know anyone that has "cracked" the P12's code. That's why we normally use the P06 for the F22A. That's been cracked. cloudasc has been working with the PT3 and PT6, and has essentially "cracked" those.
                      When using a "custom chip", the base ECU matters very little. This guy's chips should be as usable on a PT3 as they are on a P12. Since he says P12, that alone makes me wonder how competent he is.
