timing maps timing curve aem
    i am going to run aem ems v2 and need info on what the timing needs to be maxiimum and minimum. or if anyone can shed some light for me or can tell me what theres is so i can compare thanks
    does anyone know anything on this
      I'll help you out some give me a few hrs thou.
      Take a look at my MRT!! Thanks
      http://www.cb7tuner.com/vbb/showthread.php?t=186609
        that would be awesome...the ems v2 wont start my car..im using the basemap that bisi sent me and it wont fire it up...if you want i can send you my basemap so you could take a look at it
          I am not sure how much help this will be, but here is an ignition map that the pt6 uses; sorry that I do not have the scales completely figured out.
          Anyways heres the rpm scale, for the columns (probably rows in your editor)
          500, 699, 849, 1000, 1300, 1500, 1799, 1998, 2226, 2500, 2701, 2995, 3498, 3997, 4496, 5000, 5498, 5990, 6510, 8012
            thanks alot man...would you know if that would cause my no start issue? because the timing map on mine is way off from those numbers
              My software loads the values left to right top to bottom (like I read them in the rom). Eg my columns should be rows, and vise versa. The -6 corner should be in the top right. So the map should be rotated 180*. Or if since we read everything left to right, top to bottom, if the map was reloaded propely in my software, it would take the first value, and have it load the bottom right corner, going up, then moving left one column, and repeating
              Honestly if bisi sent you a basemap, it should start your car, you probably have other issues with your setup.
                yea but im not sure what it could be. the aem is brand new the motor was built 2k miles ago and runs on the stock ecu...it was saying 0 timing when cranking the car...so im not sure
