i am going to run aem ems v2 and need info on what the timing needs to be maxiimum and minimum. or if anyone can shed some light for me or can tell me what theres is so i can compare thanks
timing maps timing curve aem
I'll help you out some give me a few hrs thou.Take a look at my MRT!! Thanks
http://www.cb7tuner.com/vbb/showthread.php?t=186609
I am not sure how much help this will be, but here is an ignition map that the pt6 uses; sorry that I do not have the scales completely figured out.
Anyways heres the rpm scale, for the columns (probably rows in your editor)
500, 699, 849, 1000, 1300, 1500, 1799, 1998, 2226, 2500, 2701, 2995, 3498, 3997, 4496, 5000, 5498, 5990, 6510, 8012
Originally posted by brand0n327 View Postthanks alot man...would you know if that would cause my no start issue? because the timing map on mine is way off from those numbers
Honestly if bisi sent you a basemap, it should start your car, you probably have other issues with your setup.Last edited by cloudasc; 06-04-2012, 08:47 AM.
