First off, not sure how much input I am going to get here because it seems not many people around here use Hondata for their ECU tuning.
And don't start bashing me for using it when Crome does the same thing, which it might as far as fuel maps are concerned but what Hondata does have which makes it super fucking good to use is:
-No chips or chip burners to deal with. USB connection is the only option
-Onboard and real time datalogging standard
No chips makes it really easy to modify a tune, or change launch control settings for track days.
All that being said, I want to use my ECU to my advantage when I do compete in Autocross events.
Car stats; static:
H23A VTEC Blue top 167hp DynoDynamics
T2T4 tranny w/LSD
Competition Clutch Stage 3 Clutch
16''x7'' Enkei RPF-1
205/50/16 Dunlop Direzza Star Spec tires
Saturday I had it out and was only really focused on the launch control side of things, got it dialed in at 3700 RPM launch with a bit of feathering on the clutch provided a pretty good launch with almost no wheel-spin at 32psi in the front tires.
Once I pulled the datalog files and looked at them the top speed for the day was 62 mph, and the RPM ranging from about 3000-7300 rpm over the course. I noticed the engine dropping out of VTEC a lot, and then having to cross back over. With my current tune, VTEC is engaged at 4500 RPM. Realistically I think it would be best to get it on a dyno and have it tuned for VTEC to engage around 3000-3500 RPM just to decrease the lag time for the secondary lobes to engage.
In the type of racing I do this can be advantageous because the run times are typically around 1 minute or so and can have several very tight, slow areas. Obviously I would not drive around every day on this type of map, just go to the track, load the racing map, race, load the street map, and go home.
Another thing I am seriously looking into is getting a wideband to also hook up to the ECU to provide actual data with real meaning to see the AFR because currently I run with no O2 at all.
Tuners of the world, chime in and lets bounce some stuff around.
Car stats; static:
T2T4 tranny w/LSD
