PT3/PT6 Tuning Software
    Originally posted by reklipz View Post
    I've actually already contacted a few companies regarding finding the datasheet for this chip. I read that someone contacted ROHM Group / LAPIS Semi (what OKI Semi has become), and they came up fruitless. The details were lost in the acquisition/merger.
    Here's an image, enough said:
    -- edit --
    Hmm.. I just got a reply:
    http://desmas.net/D__CTM_CSI.doc
    -- end edit --
    I am currently seeing myself as fulfilling your prophetical someone else, and perhaps also the right person. You're coming along for the ride, btw.
    I feel like we're getting a bit OT from the topic of the thread. Perhaps we should have a moderator clean this up and split the two?
    I just need someone to understand the assembly language to make everything come to fruition. All I need to know is what memory addresses to edit, with what, or what formula to apply to the values for display purposes. Also figuring out the other side of the map scales is a high priority, but can always be figured out on the engine simulator. If I ever acquire an Ostrich/Demon I plan to add RTP support, for now I have an equivalent work around, to fill that void. Also in regards to datalogging these ecu's should be possible as a cn2 connector exists, although the rom code to do so is missing in for the board series. Most likely either the p13 code would have to have modified to work, or adapting the same code used with the civic ecu's.
    So yeah... Those are just some of the things ahead.
      had this on my computer, dont know if it helps
      MSM66911:
      http://uploading.com/15mcd7f6/datasheet-pdf
      MRT:http://www.cb7tuner.com/vbb/showthread.php?t=164408
      And on the eight day God created Honda!
        MSM66911:
        Thats about the closest you get to finding information about the 66911 processor. That file attached is for a 6691 DRAM Interface Integrated Circuit. The missing datasheet is for a 16-Bit Microcontroller... it should look similiar to http://html.alldatasheet.com/html-pd.../MSM66201.html
          I got a pt3 (with the LED)
          another pt3 with out the led eyelet
          an OBD1 AUTOMATIC ECU FROM AN INTEGRA
          and a spare P12
          would any of these help the project?
            Bumping this up to remind everyone of the hard work going into these cars from other member enthusiasts. Keep it up, Anthony.
            I'm e-mailing you now.
              You can add me to the list of testers, Ill just have to come up with a chipped pt3/6 by then lol
                Bump, how is the project? How was the move?
                  Haven't had a chance to really continue the project, been really busy settling in here in California, I still do not have my desktop setup. When I get a chance, I plan to finish a few items, and then release a free developer edition so others can use the tool to look at the factory programming. Only feature that will be disabled/removed from code would be the save routine (which is currently unfinished). For each view mode, the save routine has to convert the view back to hex, and the current working memory updated in the proper locations.
                    Question,
                    I was wondering if you will be selling Chipped ECUs with a basemap ?
                    I have a stock F22A1 5-Speed with a LSD H22A Transmssion(i had to take out my Tuned H22A) and the lose of punch when i hit the gas is killing me.
                    Jesus drove a Honda, he just didnt talk about it like us. Proof - John 12:49 "For i did not speak of my own accord."
                    den das al u ned u no dat u get wurs gas milge tho rite?
                      Not sure if this helps at all but a few of the late model dodges I've tuned recently have all used something similar to a MAF transfer function but they don't have a MAF sensor. The MAF values are inferred from the MAP sensor and the IAT sensor. I'm guessing the "MAF" table you found works similarly. Also, some GM's I've also tinkered with have 2 MAF curves. One for High MAF values and one for Low MAF values.
                      Edit:
                      I just checked out the pt-tuner wiki and on second thought the MAF tables you found are probably EGR tables. They look exactly like what I would expect them to.
                        Originally posted by tutsuo View Post
                        Question,
                        Unfortunately I do not, and do not plan on selling chipped ECUs. If anything I might offer a service to chip/convert PT3's to PT6's, or Automatic to Manual in the future. I can and will burn any 'basemap' or .bin/rom that is submitted to me, regardless of what ECU it is intentioned for.
                        Edit:
                        That is useful to know, and shouldn't be that hard to check when on a simulator.
                          Antoine, wtf are you doing with Dodges?
                          Every time I see this thread resurface, my first instinct is to open it and say "you can't tune a PT3/PT6!"... but now you can.
                            You know, I don't really like them either but if you want a flat torque curve that's still over 400 WTQ...look for a dodge. It's like the one good thing I can say about them lol.
                              It has been almost 3 years since I first started working on this project and have learned a lot. Unfortunately having a son who is almost 2 years old now, working full time, and moving cross-country, amongst other things have not left me much time to work on this software anymore. Since I first started writing this software, I've worked on several other coding projects, experimenting and learning different technologies, and have 'borrowed' code I have already written from one project to another, this software being no exception. As such I have started undertaking another major coding project (cryptco dot net), that I hope will be a highly lucrative venture. As such, with Fax4Free already being published, it bothered me that I haven't published what I've accomplished in regards to this project.
                              As such I have officially compiled the most recent edited version of my software, and it is now available for download on my site. This release is version Alpha 0.1.0.0 which unfortunately I never finished the save routine, so it is only useful as a viewer at this time, that can apply formula on the information displayed. I hope it helps someone with uncovering more information about these ecu's. Program is hard limited to reading 32KB files. Also the Version B when opening a file has a glitch on displaying the ignition maps, and will be addressed with a subsequent update over the weekend.
                              If you want to save files, I recommend copying the view data to your clipboard and saving it through a 3rd part hex editor at this time.
                              Also since this is new software, and is NOT open source, most antivirus and even web browsers (like IE) will flag the download, as such feel free to run it in a sandbox if you don't trust the download.
                                As an update, Version Alpha 0.1.0.1 is now available for download.
                                Changelog - Corrected Type B Ignition Map Start/End Locations to display properly, since they are using the 'reverse loader', it needed some small corrections.
