can i upgrade my pt6(f22a6) to something better?
ECU Upgrade For F22a
Originally posted by visualpoet View PostThe P12 won't operate the IABS. P06 tuned for your car is probably your best bet.
The P12 will be an upgrade for an F22A1 or F22A4.
The F22A6 has IAB's and the P12 does not support them.
A properly tuned and chipped P06 is your best choice, but I'd have some good mods before you do any tuning. No point tuning a stock F22A motor.Current:
2007 Acura TL Type-S 6MT KBP
Past:
1992 Honda Accord EX-R Sedan - RIP
1991 Honda Accord EX-R Wagon - RIP 10/14/2010
Words change lives. You just got to choose the right ones.
Instagram: @CB7Nub
Check out the more active "CB7Tuner Canada" Facebook group for CANADIAN members ONLY.
Heres something actually very interesting to read
Adding IAB function to a p12 ECU
http://forum.pgmfi.org/viewtopic.php?f=20&t=21718
for those who like me have done, added a H23 intake manifold, you can order the IAB adding transistors Q27 and Q11.
Q27 : 2SD1780 & Q11 : A143.
Wired the bypass control solénoid valve (IAB) at the ECU in A17, and the battery to the bypass control solénoid valve (IAB).
The intake control solenoid valve (input ECU A19) must be connected for to not have 20 error code. I have not yet found the ROM address to cut it.
Yes, its a plug and play dammit....its comes from the 92-95 prelude type s with f22a1, except it has the p12 for 10hp more than stock accord f22a1....
is obd1, how wont it not fit?
Why not just delete the stupid IAB's, and just put the ECU?
Or either just plug into a vacuum....
Originally posted by pedroalcala View PostYes, its a plug and play dammit....its comes from the 92-95 prelude type s with f22a1, except it has the p12 for 10hp more than stock accord f22a1....
Or either just plug into a vacuum....Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
Originally posted by dj_ender View PostDamn... I was simply asking if it was a simple plug and play, or if there was more to do other than just plugging it in. Take a chill pill
Originally posted by Tippey764 View Posti wouldn't say type S since that makes it sound like a good model when in reality its the crappiest model.
I wouldn't say "crappiest". It's just the base model.
The P12 is designed for the F22A1... which means if you use it on an F22A6, you're dealing with a different intake manifold, exhaust manifold, and camshaft. That ECU is not tuned for those things, so there is no guarantee it will be an upgrade, even if IAB function is added to the ECU. The PT6 is the best option.
A tuned P06 is a decent option, but only when sufficient modifications have been made to justify it. NO custom tune is going to be as good as a factory tune. Ever. And the PT6 ECU is actually tuned quite well. Unlike the H22's P13, which is notorious for running rich, the PT3 and PT6 don't leave much room for improvement on a stock or near stock engine.
I say if you don't at least have an upgraded camshaft, you don't need to even consider a custom tune.
Originally posted by pedroalcala View Posthaha i was just tired from work....grrr. but you get my point dude...
and yes, the prelude S is the crappiest model of the 4th gen prelude...good motor tho....
Originally posted by deevergote View PostI wouldn't say "crappiest". It's just the base model.
I say if you don't at least have an upgraded camshaft, you don't need to even consider a custom tune.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
