Chipped a P06, as typical with new battery, but with a VTEC conversion.
Yes I did get the correct conversion for the board type.
I have done plenty of conversions, but this is the first time I get this error.
Normally the initial ignition switch to ON starts the CEL then it goes away.
This time, it takes the CEL about 5 seconds to come on and stays on.
This is not the typical symptoms of a dead ecu, as I have seen those.
I pull the jumper on J1 and get the symptoms, which tells me it is something with stock equipment. I have replaced the battery as noted above...
anyone have any other ideas?
