calculating afr
    calculating afr
    does anyone know if there is an equation for calculating afr using certain variables like;
    rpm
    TPS
    injector duty
    temperature
    stoichiometric(14.7)
    air density
    or any others
    any info would be cool
    You can't really a calculate it (in closed loop)
    If you could there would be no need to have the o2 sensor.
    My 5.7 LS1 Holden Ute
      It would be much easier just to get yourself a wideband O2 sensor and guage.
      MR Thread
      GhostAccord 2.4L Blog
      by Chappy, on Flickr
        Technically you could calculate what your engine should do if you knew ALL the variables like the exact BSFC and volumetric efficency of your setup. There is more to it however that is way too in depth for me... It's much easier to just put the car on the dyno with a wideband, and tune your car. It gets the job done, right, without having to do a stupid amount of math.
        In turn, i'm sure you could find more info on line if your trying to do a school project or something. Try looking on megasquirt forums or something. they usually use that kind of stuff to home build a basemap from scratch.
        -Big3racing.net-
        My Build Thread. Many pics.
          http://www.jaysautoservice.com/Software.htm
          you need a 5 gas anylyzer or pay a place a couple bucks to pull a run. i use my buddies dyno/gas anylyzer at his smog station all the time for diagnostics.
