Datalogging/IAB wiring
    I have an ECU with IABs enabled for my intake manifold, and all I can find on how to use the black box is to just put in the ECU, without any mention of how to actually install wire the black box. I know that one or both of the wires for the sensor has to somehow go to the ECU, but I have no idea where or how.
    Also, I have a zeitronix datalogging box that I was planning on installing. I'm just wondering which wires to splice into? If someone even just had a diagram of what all the different wires going to the ECU are for, that'd be exactly what I need!
    What black box? I wasn't aware the CB has a single sensor called the black box.
    Also I assume the Zeitronics you are referring to is A/F datalogging, Not full datalogging? - ZT-2?
    My 5.7 LS1 Holden Ute
      yah it's the ZT-2.
      The black box is the most common name I've heard for it, but I think it's also called the Intake Air Bypass solenoid. it's the black box that's on the bottom of an H23 or F22A6 intake manifold. It's got a plug with two wires that go into it, and they tell it when to open the IABs and when to close them.
        yah it's the ZT-2.
        I don't know what the box is for, but the opening/closing is controlled by the ecu.
        I'm sure someone else will know the ECU pins for IAB's.
        I know how to connect a narrowband to the stock ECU but I'm not sure if a wideband will work.
        I'll have a look and get back to you.
          The opening/closing is controlled by the ECU which has an electrical output which goes to the box which causes it to open or close at certain RPMs. I just don't know which pin I have to use, and whether I have to solder a wire into the harness, or if there's a wire I splice into.
          The instructions for the zt-2 can be read here
          http://www.zeitronix.com/installatio...structions.pdf
          I'm sure the simulated narrowband o2 output replaces the factory o2 sensor, not sure what I can use for an ignition based power source, ground is easy enough. Dunno what the other stuff connects to though.
