does any one know of where in sacramento i can get an si ecu chip reset
chipped ECU resetting in da 916
~CB7 Phoenix~
(picture missing help me get a new one )
The California White Tux
*and its alive!! hahaha*
*under construction*M.R.T: http://www.cb7tuner.com/vbb/showthre...=1#post1689652 *changes soon to take over*Tags: None
u can do it. there is a step by step ecu reset in the DIY section. should be the same for a civic
Originally posted by Cakeboy View PostECU reset procedure: Reset the ECU by pulling off the negative battery terminal and removing the back-up fuse for 15 minutes. After the time frame has passed install back everything. Turn on the car and let it sit for 5 minutes and you're all set.
yeah but will it reset the chip in the si's ecu~CB7 Phoenix~
