I think I'm gonna want an oil cooler on my motor when I get it done, but I don't really want to mess with a thermostat and a seperate air/oil cooler. The radiator I have is for an auto, so it has the trans fluid cooler built into it. What do you guys think about using that as my cooler? It should function like the stock h22/h23 cooler, right? Those just ran the engine coolant past the oil to help keep the temps in check (both warm and cool). The radiator should work the same, correct? I could always change it to external or add an external cooler if this one doesn't keep it cool enough.
Thoughts?
Thoughts?
