What throttle body?
    What throttle body?
    I'm using an h23 manifold and need/want a big throttle body. I don't really want to go with a Maxbore one, though I'd be able to keep the FITV.
    I'm looking into a 68mm Professional Products throttle body for an ITR. They also have one for a GSR. Is there a difference?
    I'm open to suggestions to throttle bodies. I just want to confirm that the ITR is a good application to steal from since there isn't much for the H22/H23 more than anything.
    they say that D B H and SK2? T/B are interchangable to what extent I do not know. maybe some one will chime in. How much dowe is that T/B btw.
      an s2k throttle body fits.
        I want somthing a little bigger than a stock s2k throttle body. I've also read a lot of places that all but accord F motor TB's are interchangeable, but there are 2 different TB's for the teggies for a reason. I've also seen the intake manifolds are different P/N for GSR vs B16 or ITR. Something must be funny with the GSR.
        The professional products TB comes in either polished or satin (stock look) finishes, and 65mm or 68mm diameter. They all sell for about $150-160.
          I honestly don't think you'll need a 68mm TB. I had my H23 TB bored out by maxbore, and there was a slight difference
          Originally posted by DoctorCipher
          ...the beginner forum was created to provide a place for all the stupid ass questions to pile up and fester, kind of like huge globs of mayonnaise left in the sun for weeks at a time.
            ^widda is betta ^^
              do you think a lot more power is to be had by just boring out the TB from 62mm to 68? b/c i've got a 3 inch AEM intake that could probably fit it. But once your bore out the TB won't you have to do the same w/ the Plenum?
              member's ride thread
              91 Accord SE 176k
                yes he would have to have the plenium match to the throttle body, other wise adding a bigger tb is pointless
                  I don't know the exact specs of your build cus I just don't remember, but what are your power goals?
                  I think you'll be fine with an s2k throttle body if you're going with anything under 220whp.
                  Anything bigger you will lose some velocity.
                    send the s2k throttle body or h22/h23 throttle body to maxbore and let em bore it out.
                    http://www.maxbore.com/
                    My Members Ride Thread
                      I'm hoping for about 230whp, maybe a bit more, however that may be me hoping for too much. The motor is about 11.8:1CR, should rev to 7-7.5k rpm, and has .430" lift cams.
                      PirateMcFred made 200whp on 91 octane, 5000 ft above sea level, stock intake manifold/TB, and stock cam gears. I'll be using 93 octane a 900ft above sea level, Blacktrax Manifold, adjustable cam gears (tuned), and whatever TB I decide to get.
                      You really think the S2K TB would be enough? I'd like to keep FITV.
                        As I understand a Throttle body can only be bored out 4MM, according to maxbore.I was dealing with the same issues with my Skunk2 IM, it was alot smaller opening than my H22 TB from maxbore and a hell of alot smaller than my 69MM TB from DH Racing.I wanted him to port and polish my IM, but it wouldn't have been worth it so i went with thinking outside the box and got his accopanying(sp) IM
                        This fucker makes an H22 scream like a bitch cryin to its 2-stroke mama!! Especially in the VTEC range,then again what other range is there?LOL back on subject I'm just trying to give some insight.ive fought and researched trying to find a true powermaking intake setup(T.B., I.M., runners), went through 4 T.B.s not to mention the S2 I.M. was a let down.So I bit the bullet and wanted to have fun and in fact was a little sceptical on the deal at very first.It was basically my own experiment with DH's parts LOL.needless to say it satisfied me, up the fuel by around 10 psi and go...sorry to whore the thread... ...
