should i learn to drive stick with a lighter flywheel and short shifter?
    i want to do a transmission swap soon, but i gotta learn to drive stick after the swap too. but i also want to get a short shifter and lighter flywheel.
    would it be too much for me to handle?
    shorter throws, faster revs
    MY CB7
    FULL part out thread:
    http://www.cb7tuner.com/vbb/showthread.php?t=204494
    shorter throws wont really matter, and if you can handle the revs, and have some throttle control, i think you should be fine.
      my best advice to learn how to drive stick is to understand eactly how a clutch and flwheel actually works. once you understand this to its fullest, then you can better control what yu are doing
      Formerly 91AccordExR33
      11.68 @ 127mph
      417whp/375wtq
      Sold: 8/2016
        well its probably the best time as any, it took me awhile to learn to drive m civic with the stage 3 clutch, but I am getting the hang of it. If i were you talk to a friend with a stick and see if you can practice on his car, also go to how things work and type in manual car or something like that, they have a few good pointers.
        Click Me
          how long is awhile?
          like a few days?
          weeks?
          MY CB7
            Not everyones the same but the first time i drove a stick i already understood how a manual tranny worked so it was no problem.
            you prolly wont be able to drive perfect for the first couple weeks. like the first time you take off on a hill, you'll prolly end up pelling out a lil.
            a couple weeks.
              Originally posted by b3nsonx
              how long is awhile?
              like a few days?
              weeks?
              It took me 4days before I was on my own driving. I think alot of it was fear of cars behind me because I couldn't stand tailgaters when I'm on hills because I would roll back slightly...but out here in in SanFrancisco especially, people like to inch up as close as they can to your bumper for whatever reason which is very annoying. Balancing out on hills and starting off in first gear is the most hardest things in the beginning. After awhile it becomes second nature and you don't even think about it. Right now I like break checkin' those idiots that inch up too close. When I see them coming up, I just keep on rolling back and fourth playing around creating my space on the hill.
              Another thing is, not all cars feel the same. I drove a few of my friends CBs that are manual and they don't feel nothing like mine. Compared to theirs, I have to fight with my clutch more as it feels more stiffer to press down...but I actually like it that way. Some newer cars I believe are more forgiving and easier to drive like a 2007 Si. I couldn't believe how far I let go of the clutch and it doesn't feel like it will stall out. Also while shifting threw gears...i swear the clutch is so soft it feels like the clutch is there for decoration and not even needed.
              If you have a friend that trusts you not to burn the clutch or thump real hard and break motor mounts j/k on that part You can always get your folks to rent out a car to practice on.
              But believe me man, you won't regret changing your car to a 5-speed. It will be much faster and more fun to drive.
              I am the Yakuza CB7!
              JDM 96spec H22A 178HP 149TQ
              "The JDM Fleet"
              1993 Accord Sedan - 2.2 JDM H22a
              1994 Prelude V-Tec
              1999 CL 3.0
              2000 Prelude
              2010 Accord Crosstour - 3.5
              1993 Mirage S Sedan - 2.0 4G63 Project Evo 2.5
              1994 Mirage S Sedan - 1.5
              1991 Isuzu Impulse RS - 1.6 AWD Turbo
              1993 Asuna - 1.8 "CDM Impulse XS"
              1993 Sentra SE-R - 2.0 SR20de
              1995 200sx SE-R - 2.0 Sr20ve
                it will be easy when i got my swap done i had a 11.5lb fly wheel its the easyist car iv driven
