piston-to-valve clearance. F22a?
    Does has know what the piston to valve clearance is on an F22a with stock compression and stock cam? Does anyone know what it is with stock compression and the 272 cam?
    I need this info for some special valves I'm having made...I'm going to test them with the stock cam and the Delta 272 grind, but my spare motor is in pieces so I have no way to check the clearances myself.
    Any help would be appreciated.
    -Kyle
    SOHC Non-VTEC F-series for life
    "It is the fools prerogative to utter truths that no one else will speak."
    -Morpheus (The Sandman)
    im guessing here, but i want to say 150 thousandths
      Is that on the stock motor?
      -Kyle
        i guess...?
