MSD Blaster Coil 2
    MSD Blaster Coil 2
    Check it I was able to get a MSD 2 Coil for cheap as hell. BUt my f22a1 has a internal coil Will i have to buy tha MSD cap? Or can i hook \it up like that!!!!
    H23?
    just find a dizzy from a 92-93 cb7 and make sure u get the resistor box with it. U won't be able to switch a couple of wires around with altering ur current dizzy alot to get the blaster coil 2 to hook up
      I was thinking about that but what about just buying this
      http://www.overboost.com/obs/product.asp?pid=32582
      Dosent seem to expensive
      H23?
        go with the msd cap man, ive been there and done that, took me like a month to find the right shit.
        i tried making a cap....didnt work, brought the cap for the msd 92-93 accord.....there not the same
        i tell u what cap u need to get if u decided MSD.....the 92 LS integra cap, or the civic cap....(both the same)
        its a direct fit.
        the cap ur looking at, it says 90-91 so maybe they made one for our cars sense i got mines, but dont get the (i think is spelled) Haticchi or something, they do not fit.
        NEED RAP BEATS.....
        www.soundclick.com/akcidentaltrakz
          anyone wanna help me hook this damn thing up!? I got the SCI box, the blaster 2 coil, and a distributor cap off of a integra, 94-97..my friend wit a civic hb hooked it all up, and said this is the cap I need..so, whatever. Anyway, I know I gotta relocate the battery, so I got room for this stuff, but how must I hook it all up?
          -A. Swift
          CB7 member number 137
          Black Doubt Crew member #2
          Ebay Whore Club member #5
          -I was at the dentist, breathin' in some nitrous oxide (laughing gas) and all of a sudden..I ran faster!!!
          AIM: boostinswifty38
          alipne 7995 deck, pioneer 400w 4 ch amp, and all the wires for sale..500 obo!
          R/C cars and a heli for sale..2 airbrushes, paints, bodies galore..etc etc..tc3 and xxx buggy for sale..400 for it all! hit me up for details n pics
            i did a DIY on it a long time ago, forgot what forum tho, but ill tell u, cant do it right now but sometime today i will, if i can remember
            NEED RAP BEATS.....
              ok here goes, I don’t remember what wires are what color but im pretty sure you do so ill just say positive (+) and negative (-)….
              Remove the dist. Cap
              (for internal coils) you should see the coil, the largest thing under the cap with a stem, 2 screws hold it in place remove them.
              The hardest part of installing this is running the correct wires from the distributor.
              After removing the coil there should be a few wires attached at the bottom end, I think there attached with screws.
              Remove those screws but take note as to whats – and whats +, the symbols should be right over the screws telling u whats what.
              U want to run the positive wire from the SCI to that positive wire that was on the stock coil u removed.
              Do the same for the negatives, match the SCI negative to the stock coils negative.
              Also forgot to say, u don’t need the stock coil anymore so set it aside and keep it just incase something goes wrong u can wire it back up.
              Now from the SCI u should have another set of wires, - and + that go to the blaster coil.
              Match the negatives up and the positives up.
              Find a good mount area.
              Solder the wires for good connection, tape them.
              Guide the wires out to the side of the distributor where the rest of them go out at, put the cap back on, PRAY…lol and crank it up
              If u just have the blaster coil u do the same process, just eliminate the SCI, take the wires from the blaster coil (- and +) run it to the wires that came off the stock coil
              Hope that helped
              NEED RAP BEATS.....
