ok the h22 in my prelude is fucked up. The head had this white grease all in it and a little moisture around. The white grease/sludge was really thick, so i'm not sure if it is moisture. The motor makes an ass load of blow-by, has a ticking that is best heard right above the freeze plug on cylinder 3 on the block and barely heard on the head or anywhere else. I pulled the oil filter last night and barely anything came out of it but the oil wasn't too bad. The oil pressure light is always on but when the motor was ran with the valve cover off it had plenty of oil pouring down on the cams. and if it really didn't have good oil pressure then the bottom end would be smoked by now after the previous owner running it and driving it. And my time from diagnostic failure. So what do you guys think. Oh and the bottom end was rebuilt by da9b16 and i bought it off of him. I put new rods and mains in it, oil pump, and oil pressure sender after i blew it up once. OH and compression test is
cyl 1- 175
cyl 2- 165
cyl 3- 165
cyl 4- 160
so what do you guys think
cyl 1- 175
cyl 2- 165
cyl 3- 165
cyl 4- 160
