Just about every week or two depend on how much i drive the bolts on my headers to the downpipe all come loose. So every week i have to tighten them and buy a new gasket because every once in a while i wont get to it soon enough. And the metal gaskets keep on braking. Is there anything that i can do to keep them from getting loose all the time? Would a different type of gasket work better? I gotta figure something out so i can drive this weekend. Thanks
Exhaust leak
They have that high temp silicone you can use in between that should help adhesion a bit. You might just need better bolts But I would tighten them with the silicone first and see what happens. Whenever you take off is the gasket bad? You can tell if it has been leaking because usually the exhaust will leave a trail where its comin out of.
