OK, again, looking for some input on a mild build-up on a H22. Basically, I am looking for close to stock reliability and driveability, but want a little more power than a stock JDM H22 will deliver. So, I am looking at some mild engine modifications in conjunction with normal bolt ons (I/H/E - except for maybe keeping the JDM header).
Anyway, I am considering a cam swap with new valve, retainers, etc and would get a little head porting done at the same time. My question is, while the head would be off (probably before install in the car), what about milling the head a little to increase compression ratio a little? I am not looking for a whole lot. The stock JDM H22 is around 10.6:1, right? Something to maybe get to the 11.0:1 range? Or is the safer alternative doing new pistons? And should I consider new pistons the way to go just in case I ever want to run a small shot of N2O anyway?
Or, should I just install the H22 stock, get that going fine, then consider something like the Gude H22 head/cam upgrade and maybe do new forged pistons at that time in the project?
Any thoughts?
Any thoughts?
