Apexi AFC
    Apexi AFC
    Hey does anyone have the apex afc to control your air fuel mixture? Im thinking about getting mine since im about to do some modifications to my intake system, manifold, throttle body, and my cam. So if you have it let me know.
    To have loved and lost is better than to have never loved at all #CB7Life
    i have one, but you cant go by anyone elses specs. to properly tune your car, you will need to put it on a dyno equiped with a wideband o2... and adjust accordingly.
      yeah but i thought it had an air feul ratio meter in it? if it does why do you need to go to a dyno is you can adjust air feul by yourself. Dyno would be optimul though.
        cause your car reads on a narrowband 02 sensor not a wideband. Narrowband 02's are not nearly as accurate...its like telling the ecu the car is running lean...but doesn't say how lean its running ya know? Although the afc does have a a/f gauge built in it is not accurate. Seriously put it on a dyno with a wideband and you'll see how off a narrowband is compared to a wideband sensor. Do some research between the two subjects and you'll find your answers.
          i'll do a diy on the afc install also i guess
            i had no idea it had a afr readout, where is it at? if it makes a difference i have the vafc, not safc.
              o thank you very much for the info please post adiy that would be great
                I'll git er' don today lol...theres an a/f ratio readout in one of the modes. Go to www.apexi.com and search through the manual for the vafc's if u don't have the physical manual anymore...gimme a couple hours or so and i'll have you diy up in no time hopefully
                  finished the safc install...i will post the diy once i upload the pix and come up with the tool list
                    sorry for your wait sir
                    http://www.cb7tuner.com/vbb/showthre...&threadid=7044
