HELP!!!!! OIL is leaking!!!
    Ok, I jsut installed a new sender unit, after the guy I bought it from gave me the wrong part. This unit looks like a lobed-shape can..i would say like gold in color. One end you attach a gold adapter for the block, and the other end you attach the wire from your gauge. Well, I swapped it all out, and now my gauge is pegged at over 100psi. the thing that scares me is it's leaking oil! I drove it home from work (about a mile away) and it got all over..i smelt a burning smell, and smoke came, off of the header! I think it's comming from the unit, but I am not sure..i lost like half of a quart too! Someone, PLEASE help! I can't afford to have a blown motor..I really can't..
    -A. Swift
    CB7 member number 137
    Black Doubt Crew member #2
    Ebay Whore Club member #5
    -I was at the dentist, breathin' in some nitrous oxide (laughing gas) and all of a sudden..I ran faster!!!
    AIM: boostinswifty38
    alipne 7995 deck, pioneer 400w 4 ch amp, and all the wires for sale..500 obo!
    R/C cars and a heli for sale..2 airbrushes, paints, bodies galore..etc etc..tc3 and xxx buggy for sale..400 for it all! hit me up for details n pics
    did u put "thread" tape or a teflon seal on the threads before installing? you kinda need that =)
    Retro!
    Hater
      I JUST replaced this oil pressure sender unit on my car today!
      I was getting a leak, that trailed down the oil filter housing down onto the header, that created a burnt oil smell into the cabin.
      Anyways, once this starts leaking it gets worse & leaks more. I was up to one quart a week.
      Anyhow, you're problem is you probably installed it wrong. You need teflon tape or the liquid version like I put on them pipe threads. Then you start it by hand & because it's a tapered fit, you finish it off with a torque wrench to 13 lb-ft. I bought my unit from Advance Auto Parts for like $7.50.
      You might as well do an oil change and while you have your oil filter off....do this job, install new oil filter & put in your 4.5 qts of oil.
        Be careful not to put teflon tape or the liquid sealant version on the opening in the pipe threading of sender unit...don't plug it up!
          well, i did it right..he gave me the wrong adapter, and i put some tape on..and put mroe oil in my car at tires plus..btw..it's 3.7 quarts of oil..not 4.5...
          -A. Swift
            BTW...I'd rather use the liquid sealant rather than teflon tape, I feel it seals better.
            Anyhow, when you install the part, it has a tapered pipe thread. So you tighten it by hand and you'll feel it bottom out. At this point, use the torque wrench and tighten it down to 13 lb-ft.
            What do you mean adapter? You shouldn't need an adapter for the correct part unless it's a ghetto part you're getting.
            EDITED: Cuz I was being an ass Least I admit it.
              i think it depends how much oil u take out of the system...
              cause i put in about 3.6 quarts and its full...
              oh well glad u got it done
              id rather use teflon seal as well....that liquid stuff..especially for any gas lines
              Retro!
              Hater
                Ok man, settle. I am not all up on you about it..I also think it depends on what filter you use. I use a tf2808 filter from work( I work at tires plus, as a mechanic, and general service tech..including oil changes) so, I only put in 3.7 to start wit..sometimes it needs more, sometimes less..
                -A. Swift
                  Are we talking about the oil-pressure sensor? If so, I ganked one from a D16 and tightened it by hand. No sealant...go gasket...no problems.
                    u were just lucky. sweet fit though.
                    and about the differnt oil filters, yes differnt oil filters have differnt capacity. like if you were to use a fram, it would be about 3.8 quarts i think and maybe a differnt filter more or less depending on its capacity and dementions inside.
                    so that can be a possibility. also even if 2 filters are the same with 2 differnt fill capacities, doesnt mean the filters are identical inside cause some are made in the US, canada, japan and else where...they are all differnt but in the same way.
                    just as long as that oil is up between the 2 dots on the stick is all that matters =)
                    Retro!
                    Hater
                      WIX oil filters are best. Argue not. They own you.
                        I use Purolator oil filters...so maybe that's why the differences. Yea, I've heard WIX filters are good too, I work for the company that makes them...Dana Corp...I could get a discount from NAPA on that shit, but I don't for whatever reason.
                        Sorry Swifty....I'm just pissed from other things today & the oil filter differences is prolly why.
                        Anyhow, is it leaking still?
                          naw man..it's all good. I can drive it as hard as ever before..partly so i can change my dc sports headers fully ot hte blue/purple look..now, I gotta fix my locks ,and get the fuckin thing lowered..btw..anyoen want a set of brand new eibach pro-kit springs? It's just not gonna be low enough for me..
                          -A. Swift
                            yea I've heard this...the Eibach sportlines are supposedly lower.....look into H&R sport springs too.....or go coil over sleeves...I hear ground control is good for these if you get this type for lowering.
                              where can I finde these h&r Springs? I was indeed ognna get the eibach sportline springs, but if the h&r are good, and cheaper..then they are the way..lol. So, I take it no one wants some springs..new?
                              -A. Swift
