f22a turbo?
    f22a turbo?
    u think it would be alright to turbo charge a jdm f22a motor i just put in they say it has around 45,000 miles on it but who knows run like a chamo how much boost should i run and what not ...?or if u guys even think its a good idea
    Run a compression test on the engine first, And its your choice weather to boost or not. But if u do get it tuned really well, even at 8psi u still need good tuning.
      i heard accords can take 30 psi ....go try it
      Old Ride-New Ride
        haha uhh right my friend fully built supra does that and i dont think thats really a good idea
          stock dont do more than 8psi and get a good tune just to play it safe, those were my plans.
          Not my fault my dick only fits magnums.
          Why drink and drive when you can smoke and FLY?
            If you do the proper maintenance and compression test is good then you can boost it. Make sure no seal leaks and crap like that. You can run up to 10psi daily depending on your tune. Most people run 8psi or so.
              its called sarcasm.....this kid didn’t even try
              his is one of the most lazy posts I’ve seen a while
              Old Ride-New Ride
                You could run up to 14psi but I wouldn't!
                99 GS300 (Aristo) 2JZ Power
                Bought from:gdout, bb6-sh
                  Yes, it'd be alright as long as you tune it good. Like everyone has said about 8psi will be good. And you can of course run lots more if you build the engine up. I say it's a good idea, because everything needs a turbo! lol.
                  Sean-Dinner.com
                    If you don't have the engine yet, I'd suggest the F22B. d112crzy is hangin with h22's with his f22b. Then you turbo and the things a f'kin beast.
                      yeah i got the motor for a local jdm engine dealer and they did a compression and leak down check b4 i bought it new seals and what not ..its already installed
                        where do u think i can get a decent kit is anyone selling a good one other than that crap from ebay uh i hate that stuff stay away from ssautochrome
                          People have good and bad opinions on SSA personally I know a couple people running there manifolds and havent really had a problem with them yet. But if you worried tried to source a kit out of a DSM which would be the cheapest way but it has everything you ened basically.
